That normal. Replace that throw out bearing while you have it there. Pilot bearing would be good to replace as well.
Thanks Wes. New clutch and all bee bearings going in. I gotta PM you this month for that trans cover. Things got crazy with the mail and the hurricane so im going to wait for things to settle down.That normal. Replace that throw out bearing while you have it there. Pilot bearing would be good to replace as well.
Alright. Not sure whats happening here. This power steering hard line coupling bottoms out before the flare makes contact. So the hard line moves and leaks. The flare is not damaged. What am I missing?
In your photo, are you mixing-and-matching head bolts and head studs?
Second that! Way to go...Congrats!
