Fan clutch is fine don’t worry about that. If the oil pan is leaking, there’s not much you can do about it with it in the truck
You'll have 20+ psi at hot idle if you use an oil galley for the gauge port. Seems to be less for most members here if you take it from the stock sending port but these oil pumps are high volume, not high pressure, so 12psi at idle wouldn't be bad. That said you will also have over 40 psi under hot load.Cant thank you guys enough for the help. It is much appreciated. Ill see if I can pinpoint the leak hopefully it can be fixed as easily as everything else. See if the oil pressure sensor thingy can be tightened or twisted or jiggled and mess around with it a little. If i have to end up getting a guage oil pressure needs to be a minimum of 7 psi at idle?
Haha yeah I'm sure you could use a UV dye for A/C systems in the oil, or maybe there is a specific product for oil... but the concept is great. I used it for a coolant leak a few months ago that was driving me bonkers.Replaced the sending unit with a BWD from advanced, oil pressure gauge works great again. Now to track down this leak. I borrowed a black light from someone at work so ill see if i can track it down after timing tonight.
EDIT Okay so the oil we use in the airplanes glows under black light. I guess thats something special they add into the oil to find leaks that good old rotella does not haha. Im trying to drive the truck to get the oil a little dirty, its so clean I can hardly tell where it is and isnt.
Thanks laser.If the rpm is jumping around, check the mag probe distance to the crank. I had to go from 3 to 2 business cards away to get a stable rpm signal.
Mine was done by previous owner but it seeps a little, figured this was the case. Oh well ill deal with it for the time being.Fan clutch is fine don’t worry about that. If the oil pan is leaking, there’s not much you can do about it with it in the truck
