PackRat239
Sure looks like thats the wrong hole dude. That is a blind bolt hole. Sorry if I posted too late.
UPDATE: @packrat: it is definitely the glow plug hole.
I cranked the engine, i think 5 times around without the wires connected (both) to the fuel pump, the hole covered with an old t shirt.
I strayed wd40 inside the hole 2h before. After that i tried to insert a screwdriver just to test if the hole is no more blocked.
I could not find anything shot out of the glow plug hole BUT the screwdriver just fall in!
I screwed in the GP, just without any issue!
Though the batteries are dead now, i need to wait fir charging... but first issue is done.
btw: my guess is that the GP relay is not working. As far as i read there are different sounds showing if it's working correct. It clicks 5/sec and sometimes 2/sec. Warm up shows ca. 5-10 sec.
While "warm up" and a GP connected to the harness outside the engine- should this begin to glow? I would guess so.
Geez, I got dressed and went out at 9:30P at 10*F and took pics of the U-haul Van engine, to verify the GP hole.Sure looks like thats the wrong hole dude. That is a blind bolt hole. Sorry if I posted too late.
What ever was blocking, it has been inside before, I am sure.
Though it did not start with 2 times cranking. Although a bad idea, I used start pilot, just a min tip.
It started immediately and run smooth. After some minutes I tipped the throttle a little and it runs still smooth and rpm went up easy. Restart after some minutes worked.
So GP probably still not work I guess.
Relay, harness... Not a concrete idea.
