38 gal fuel tank diesel/gas??
Dillonn
South Texas
I was thinking about putting a 38 gal tank in the back where the spare tire usually is. The tanks I keep finding for my 86 f250 keep saying gas only. So what's the difference in the tanks? Can I use a tank that's for gas in a diesel application?
it says gasser, because you cannot get a diesel sending unit for it...
so what do you do?
make it for diesel
hesutton
The Anti-Anderson
Bowling Green, KY
I put this sender in this tank on my F350 a few months ago.
It works just fine. 500 miles easy (when not towing) out of that tank before having to switch to the front.
The tank comes with hanger bolts and parts to mod your sending unit. My old unit was *****, so I just modified the new one.
I worked as well as the stock tank did with my TransferFlow filler neck too. ;Sweet
Heath
hesutton
The Anti-Anderson
Bowling Green, KY
Modified sending unit.
Heath
Some one on here was looking for a large tank with a sump in it so they could get the last drop out of it. Maybe he'll see this one.
Greg5OH
MI
^i would modify a cab and chassi tank in that case. the older ones were steel i believe, and 50 gals. weld in a sump for it.
My 94 rear is poly, front is steel.
Still only the smaller 20 or so gallon units.
The SD Era used the 40 gal from F250-F550 including C&C trucks.
I would like to know what tank you're talking about though. Lol
Greg5OH
MI
hrm you are right! I swear is saw 50 gallon when looking at tanks before
Guess the excursion 44 gallon is the biggest one you can get (from stock)!
Love the range mine has :D
ntjapkes
