1984 7.3 powerstroke build
I believe he used the tractor sitting next to the truck in the last picture. If you don't need to go very high, you could probably get away with using a couple of jacks and some wood blocks.
goldsjos18
wisconsin
Yes sir my little garden tractor lifted the cab just fine with out a problem if you needed to you probably get a group of people and lift it off it's really not to heavy
goldsjos18
wisconsin
What did you use to lift the cab and how "hard" was it? Needing to do the same on my 87. Working on the dash now and found out they crack easy and the frame is rusty.....
Removing the cab on this truck wasn't to difficult as this is a Texas truck so it's not rusty I'm not sure we're your from so I can't say how hard it would be to take the cab bolts off because of rust mine came off easy though
I worked in a paint shop for a couple of years. I did a frame swaps there. We just stuck a 2x12 through the windows and used our bigger forklift to lift it off and put it back on. It worked slick!
goldsjos18
wisconsin
Today I put the pedals and tightened up the fenders. Now I'm looking for some one that can help me with the dash as it would be easier with to people will get back to it tomorrow
no mufflers
rhode island
Yeah the dashboards are a pain. I found that the wiring in the OBS trucks are a lot better than the brick nose. I had mine apart many years ago and I wish I looked over the harness more to neatin it up.
goldsjos18
wisconsin
Alright so I'm sorry for not posting recently as this project had to be put on the back burner for awhile but everything should be good to go now. The truck is being trailed to a shop so I can do more welding on it as I missed some parts before so once I can get more pictures for you guys they will show up on here
Cruiseomatic
Defining Insanity
Dark side of the Sun.
Got my "new" cab bolts off VERY easily actually. Little harbor freight electric lugnut impact worked great. Going to try the 2X12 trick. Once I get one of the two cabs welded its time for paint. Got the dash out of both cabs. Not that hard really. Neatened up the wiring on my old dash I'm keeping. Have a complete red brick dash if someone needs it. That old cloth tape is a mess to deal with. Stripped it all off and re-taped it and it looks so much better. Also included the power window and lock cross body harness in the dash harness for cleaner install and its all together in one. Trying to use as much as possible from original truck so I don't have a frankentruck. Even down to clips and fasteners that are still serviceable.
goldsjos18
wisconsin
Ok guys I'm sorry for not posting in a long while I had to put the truck on hold for some personal reasons but in this last week I had gotten more done then what has bed done in the last 6 months I will upload pictures tomorrow but basically all the wiring is done and the dashboard is in place just some interior work and a few battery's and I should be good to fire up the old 7.3 PSd pictures coming in the morning
goldsjos18
wisconsin
I got all the ac components in place and hooked up quick question does the idm need to be grounded to the truck via bolted to the fender or does is have a wire to it
From what little I know and can remember, it grounds to the fender. If you don't want to do this, you can run a ground wire off of one of your mounting bolts to be sure.
madpogue
Madison, WI USA
IDM grounds by one of the wires in the connector. EVTM indicates no case ground with PCM or IDM. I've connected a spare IDM and just had it sitting loose, and it ran the truck just fine.
goldsjos18
wisconsin
sweet now all i need then are batterys rear drive shaft straps and to put the passenger side door on ig fuel lines wouldnt hurt also
dieselmainiac
