This guy has to much time!
That guy has too much time on his hands...
![LMAO LOL LOL](/styles/default/xenforo/smilies/lol.gif)
....I'd rather just filter it, mix it with some diesel and drive it...I don't need all the headaches of WVO in my cold winter climate.
You guys are waisting your time on all this filtering. If you read my blog you would have seen that you could run straight wmo in the winter and no messing around with this funky fuel filter cleaning system.
An easier set up for your truck is is to just switch the fuel filter to a engine oil filter. When you pick up your used oil you'll find that it has come out of a truck or car that was filtering it the entire time it was in the vehicle. then drained at the oil change into a storage tank. its not like WVO just suck it out with your pump and install a engine oil filter on this pump if your totally ****? I have never had a plugged fuel filter and am still running the first filters i installed on my system (HUH)? To much time on my hands has got me a simple system that can refill my onboard storage tank of 275 gallons in about 20 minutes when its snowing outside and a range of over 3 thousand miles between fill ups. plus one stock tank is still all diesel just incase.
You guys looking for a good collection pump for your fords should lok at this pump i just built. its even blows me away on its volume and its freezing and snowing. I stopped at the local quick lube after work today and got a quik refill of 250 gallons or so in just minutes. i think at fast idle i must be aproaching 20 plus gpm and i can pump it off into storage tanks or other vehicles just as fast with all the connections on cam lock fittings.
my newest thing is i am installing a steering pump from a honda for a fuel pump since the fords dont have fuel pumps to get the job done when the temps are below about 60F. if this works out i'm installing another one for transfering oil from stoarge to the main tank while driving.
If your truck is a turbo it even works better! if you have a EGT gauge and a adjustable boost control you can start to pull some of that extra power BTU's in the fuel oil.
