datkinsonsr
Ummm, yeah, guess I should have mentioned that they won't handle that high of pressure if they're empty
Remember it is Pounds per Square Inch - so if the entire inside surface is exposed to the air pressure it will be too much force. I think you'll find that if it is half full of liquid and lying on its side to where only 1/2 of the top and bottom are exposed to the air pressure it will probably handle about twice as much pressure without damage. Also using a smaller diameter drum - like one of the 25 gallon drums - should help alleviate that problem.
Even if not, 18 PSI - or even 10-15 PSI should be more than enough to push the oil through the fillter(s). 10-15 PSI is certainly more pressure than you're going to be able to generate with a hand-cranked pump.![]()
One other thing I was thinking about today is how to make it flow through the filters easier - especially in cooler weather. I think if and when I give this a try, I'm going to mix the oil 50/50 with diesel before pushing it through the filter. That ought to reduce the amount of pressure it takes to push it through the filtration unit by about half.......
Guys, PLEASE BE CAREFULL WITH AIR PRESSURE! Just some approximate figures for a 55 gal drum, @ 5 psi you are creating about 37,300 Pounds of force inside the drum regardles of how much oil is in it. At 30 psi, the force is about 223,800 pounds of force. Thes drums are not built to hold pressure!
There have been many drums blow up at 5 psi to "get the oil out faster".
