Headlamp relay harness update or improvement.
noddaz
md
Has anyone added a headlamp relay harness to their truck? The reason I ask is my truck over the years has burnt up/melted the headlamp switch plug. When I replace it I would like to add the headlamp relay harness (Bronco Graveyard) to take the load off of the stock harness and headlamp switch.
Has anyuone done this? (Of course someone has...) What were your results? I am expecting to have brighter headlamps from this upgrade also.
It is a very common upgrade. I did it to my truck, and plan to do it to my old mans truck when I dive into the wiring.
Results were brighter lights since they didn't have to go through any burnt connectors at the headlight switch.
Everyone has done it..... everyone MUST do it!!!...... please, for the love of oncoming traffic thats probably texting PLEASE add relays to your headlights!!! Buy the bronco graveyard harness......make your own, even!!! I actually made mine...... anyway, seriously, do it YO!!!
rreegg
IDI n TDI
Puget Sound
Installed the Bronco Graveyard harness around a year ago and it's been good. Think the difference in headlight brightness is slightly better but not super noticeable, I have LED fogs which were my solution for brightness issues... but the relay install is still worthwhile for wiring/electrical relief.
Only thing worth mentioning really is one side of the harness was slightly a tight fit, cannot recall which side but would be improved with an extra 2" or wiring. It has not been a problem though
Also looked into random e bay vendors and they're probably fine but would still recommend bronco graveyard
I installed two harnesses from LMC Truck (probably the same as the ones from Bronco Graveyard) into my two Bull Nose trucks. Since I also installed brighter lights at the same time, which is why I used the relay harnesses, I can't comment on the lights being brighter. I love them. They were easy to install and haven't given me any issues.
ROCK HARVEY
Dayton OH
I think this is an upgrade everyone should do. There are some really good instructions online so it’s not hard at all to build your own harness.
That being said, I did not get the “night and day” results I was hoping for until I also replaced my headlight assemblies. That was probably the best $100 I’ve spent on this truck. The internal reflecting surfaces on my original headlights were just too far gone, so the relay didn’t help on its own.
Grumpy bruce
Ca
I did it when I changed out my factory head lights that were that were 30 years old . Big improvement
Old-Red
PNWest
I'm a complete newbie when it comes to headlight relays. Couldsomeone show a pic or at least explain how this is wired up and why its desirable?
My headlights are on and off low beam, (fully stick) and only run on low once in awhile
Something should turn up on a search as far as a description of how to do it...... ill try to find the picture I used...... but all the amps from both batteries are going through your headlight switch and its gets hot enough to actually melt the connector..... and it will start flipping the switches internal breaker and turning your lights on and off willy nilly....so.... thats the deal....
Lol, Selahdoor made this little diagram for me in a PM like 4yrs ago......he also did a write up but I have no idea how to copy that over...... its really straight forward, and you can use heavier wire than bronco graveyard offers.....
89Laredo
Underemployed
Not Canada
I have a cheap $20 amazon one on my jeep tapped straight to the battery with 100w bulbs, seems to be pretty good so far. I plan on doing the same when(if) I get my truck back together. Definitely a good idea to help save the cab harness and switches, and get rid of some voltage drop.
ROCK HARVEY
Dayton OH
I used this set of instructions from FTE when I did mine, I thought they were really good:
Diseldg
Duluth mn
I recently purchased mine from summit racing. It was from painless. Probably paid too much for it but it fit perfectly and really well built. Made a huge difference in the brightness of my headlights! Can’t believe it took me over 10 years to do this, wish I’d done it sooner!
Rayfish
