Austin86250
updated for better format
*Horn fuse blows when I press the horn will never blow if I don’t press the horn
* fuse still blows even when the horn relay is disconnected
* no 12v to yellow/ LB wire in horn relay connector
* no continuity to yellow/ LG wire on the horn relay connector and either of the horn connectors
* there is continuity between the DARK BLUE wire on the horn relay connector and the spade on the steering wheel where the blue wire from horn pad connects
* the DARK BLUE horn wire doesn’t have continuity to any other pins on the turn signal switch connector
* this problem has carried over from 3 columns, 2 steering wheels, 2 horn pads, and multiple turn signal switches (these where not replaced for horn reasons)
* the horn did work at one time in my ownership of the truck but it was years ago
* the horn does work when 12v is directly applied
It is to my understanding that the dark blue wire / signal to relay from horn pad works off a ground and what the horn switch is doing is grounding the dark blue wire which activates the relay
When the relay is activated it sends the 12v coming from the fuse box to the horns
