Who makes the best valve cover gaskets?
chris142
SoCal
I have sprung a leak. I wanted to check the bolts but can't easily access the ones on the back. So since I hate working on cars I don't want to do this 2x. I have used Fel pro and Napa gaskets in the past on other cars with mixed results.
SLC97SR5
UT
I've been happy with my new, rigid rubber gaskets from FelPro. I sealed them to the valve covers with RTV so I didn't have them flopping around when I installed the VC's to the head. So far, so good.
I have used the cork and rubber gaskets with good results.
I glue the gasket to the valve cover. dry on the cast side.
they both get hard, brittle, and crack in time.
hce
So can i....
Glasgow MT (Official middle of nowhere)
I have had a poor success rate with the rubber gaskets. One side sealed up the other leaked through multiple gaskets and different valve covers. Installed a cork gasket and no more leaks. I think the rubber gaskets are stiffer then the valve cover flange. I install my gaskets dry, as rtv makes for more sealing surfaces and defeats the design of a gasket to expand a seal.
IDIBronco86
Staff online
