ZF5 Install
sle2115
NRA LIFE MEMBER
Southeast Ohio
Just wanted to ask, is there supposed to be an inspection plate that goes over the opening on the bottom of the ZF5 bell housing? I assume there is, but I don't have one...anyone have a picture?
Thanks in advance
The Warden
MiB Impersonator
Fog Bless Pacifica (CA)
Yes, there is supposed to be a plate...unfortunately, I don't have a picture. I re-used the inspection plate that was on my T-19 and didn't have any problems, FWIW...
TwoTone IDI
ZF swap completed!
Richmond, VA
theres one, it looks like a slice of cantaloupe. id love to have one if you run across it. since nobody seems to have one i almost wanna say its made out of plastic.
it's metal. I see them only on trucks that haven't gotten their first clutch job. they strangely dissapear when the trans is removed.
it's metal. I see them only on trucks that haven't gotten their first clutch job. they strangely dissapear when the trans is removed.:dunno
sle2115
NRA LIFE MEMBER
Southeast Ohio
That's good news, I'm replacing a T19 as well...hope to start on it this weekend as the T19 clutch is going south. I have a new solid flywheel and clutch as well as all new hydraulics. Just a few other "pieces" to get together to get it done.
Rumor I have heard, that when you put these aftermarket oversize SMF clutch kits in, the cover will not fit and needs modification.
hce
So can i....
Glasgow MT (Official middle of nowhere)
I used the t19 cover on mine it fit, but just barely rubbed the front on the flywheel. A few washers between the cover and tranny on the back two bolts solved the problem.
gonecrazyi
florida
When I put on my LUK clutch kit I had to bang the inspection cover out a little. The teeth of the flywheel would hit the cover and make one heck of a racket.
Sycostang67
Scooty Puff Junior
Kuna, ID
Not sure about the diesel ZF, but the gas ZF inspection cover is molded into the spacer plate between the motor/trans. It's pretty stupid since you cant just remove it to inspect anything, you have the separate the motor/trans to get a look at anything.
sle2115
NRA LIFE MEMBER
Southeast Ohio
I have a Sachs clutch set...has the dual row spring set on the clutch disk, etc. I got a great deal on it new as well, we'll see how it works out. It is the large clutch as well (12 1/4" I believe).
93turbo_animal
Marengo,Ohio
No mods to mine either and I'm leaning towards it getting bent a little during removal or something cause why would it hit afterwards the ring gear can't be any bigger or the starter wouldn't work
JU57US
Staff online
