Zf 5 swap
Warnerkc
Pennsylvania
Hey I'm currently collecting parts so that I can put a zf-5 in my 94 f250. I currently have the transmission, transfer case, pedals assembly, transmission tunnel, and steering column. I'm having a hard time finding a crossmember for the transmission. Does anyone have one that I could buy?
F350camper
BOOST!
USA
Hello there, welcome to OB.net
@subway may have one, he is in PA, he just did a major conversion on his rig, not sure if he has a leftover cross-member or not. I tagged him in this post, I'm sure he will be along shortly.
Dieselcrawler
Professional wrench holder
Staff member
Quakertown Pa
Where at in pa and which crossmember do you want? There are a few different styles.
Warnerkc
Pennsylvania
Western PA. I didn't realize there were different ones. What are the differences between them?
Dieselcrawler
Staff member
Quakertown Pa
One looks just like the one you have, and actually you probably could reuse yours just move it to where it is needed. The other goes on the outside of the drive side rail and under it.
How soon are you doing your swap I pulled one off an 89 f250 but I'm not sure if I'll need it since it seems my original 4 speed one should work.
my x member that previously held a T-19 now holds a ZF.
cant remember if i had to move it or not, but i know i didnt have to re-drill.
single mass, i didnt have a dual mass to begin with.
Warnerkc
Pennsylvania
I got an E40d transmission right now which I hate, and I'm putting in a zf5 to replace it. Will I be able to reuse the e40d cross member?
RangerDanger
