Power Steering Pump
gandalf
Senior Member
CA &/or Maine
Is there any better/larger/more powerful power steering pump for my truck ('92, 7.3) than the Saginaw? I converted the brakes to hydroboost a while back, but they're still not as good as I think they should be. The truck, btw, is running a v-belt system.
A neighbor, currently finishing some major work on his 7.3 '03 truck, suggested a larger PS Pump. Is there one available, and would it help with the brakes?
KansasIDI
I hate printers
Wilsey, KS
I am also curious about this...
My 86 had power steering issues, since it has vacuum brakes, I simply swapped to manual steering, no complaints there, this truck is very light for a 4WD extended cab diesel pickup.
I just put a reman PS pump in my 91, which has hydroboost. It is definitely noisy, but the brakes are amazing! Better than our newer Dodges at work. I am in awe at how good they are. But this truck is an F-Super Duty, so it has huge disk brakes front and rear. I have read that it is possible to convert to a Saginaw pump, but I am yet to figure out all the details, it appears bracketry is an issue...
I have also read that getting a new PS pump, new not reman, has satisfied many people.
There are upgraded C2 pumps out there that use Saginaw internals, but they cost slightly more than a Saginaw pump...
The hydro master bore is too large to make the drums happy. I file the mounting holes for the original MC and it stops waaaaay better.
gandalf
Senior Member
CA &/or Maine
Russ, I just sent you a PM on FB before I read this. The hydro bore is too large? Mine is marked at 1 5/16. The vacuum unit it replaced was 1 1/8. Re the mounting holes, do you mean the holes through the firewall? I don't recall having a problem. The 4 studs slid right through and tightened down. Is it possible that I have a poor hydro unit?
hacked89
Bucks County PA
I have a post somewhere on the forum on this, I did decently extensive testing on the hydro boost setups for these trucks swapping different steering gears, pumps, etc. The best performing pump which i now run on each of my trucks is the Edelman 6014R designed for the 99-03 F350. Bolts right on and is meant for hydroboost including the extra return.
ROCK HARVEY
Dayton OH
Gandalf, have you checked to make sure that your rear brake shoes are working correctly? There was a thread a while back about how many of them were cast incorrectly, causing them to only slightly expand and not grab the drum with enough force to provide stopping power. I ask because I swapped to hydroboost and felt a huge difference, I can lock up the tires easily.
ROCK HARVEY
Dayton OH
Here’s the thread about brake shoes:
gandalf
Senior Member
CA &/or Maine
The rear brake adjustment is a good and a valid point. Its something I'll have to check. As nearly as I can tell from my records I adjusted them about 18000 miles ago. Maybe its time to look again. If its a question of not expanding enough to properly grab the drum I should be able to see by the wear pattern on the shoes.
Dentside diesel
California
Ive got hydroboost with saginaw pump. Front disc, rear drum steering and brakes work great. Converted my idi to saginaw pump using econoline ps bracket. Couldnt get thre ford pump to quit whining. Even the ford pump ran the steering and brakes really good. that noise is embarrassing
ROCK HARVEY
Dayton OH
Gandalf, a telltale sign for me that my brake shoes had the incorrect casting was that my e-brake was weak and wouldn’t hold on an incline, even though the shoes were adjusted properly. You might want to find a hill to park on and see if the e-brake alone can hold the truck without rolling in neutral.
The_Josh_Bear
Western WA
Something I've read about (I don't have hydroboost) is that if you made the swap but didn't swap in the PEDAL from the HB setup then the pin for the actuator rod will be in the wrong spot. Obviously that's a leverage thing, and some people have the same problems and change the pin and viola, all is good again.
It's moddable, not something that requires the actual pedal to do, but can drill a new spot for it.
Write-up on how to move the pedal pin
MAster cylinder mounting holes
Lumberjackchuck
New Jersey
Hey I’m interested in the hydroboost conversion since my vacuum booster is leaking and I’d rather upgrade than replace it.
Where did you get the rest of the parts for the conversion? Can I use the same steering gearbox that I have on my truck currently or do I need to change that as well?
ROCK HARVEY
Dayton OH
When I went to hydroboost I bought the hydroboost unit, a new PS pump, and all the hoses on Rock Auto. I just bought parts for an F-super duty of the same year. I also bought a new bigger brake master cylinder that I never got around to installing, and I may never install it based on what Russ said above. Instead of moving the pin on the pedal like many people do, I moved the brake booster down 3/4” to get the geometry right.
The hydroboost unit did not come with the master cylinder pushrod, but you can buy those on Amazon or elsewhere. They come longer than needed for a “universal fit” so you’ll have to cut/grind it down.
Lumberjackchuck
New Jersey
Thanks for the info!
Jimacho
