Power Steering Pump
hacked89
Bucks County PA
Ditto, only thing I would add is I modify the pedal pin and swap to a red head box or similar rebuilt box. Not required regarding box, you can use factory box.
hacked89
Bucks County PA
Here’s my write up from the tech section
1mouse3
il
The hydro master bore is too large to make the drums happy. I file the mounting holes for the original MC and it stops waaaaay better.
I am using the f-super master with rear drums, did swap the output fitting on the the rear port since the f-super one was hollow. I was locking up the rear, so added a manual proportioning valve from willwood to sort that out since left out the oem one.
dogdanblue
