I am not having any luck in the alternative fuels section so i figured i will try here
i want to set up a system in my truck i have already swung the greascar switching valves and a 40 plate exchanger and a tank. but what i want to know is how do you run the coolent lines? i want to to a HIH setup back to the tank. so where do i split the heater core hoses? i want to be able to run as much of the year as possible (York, PA). should the flow be throught the heater core first then to the filter then plate exchanger and back to the tanks? or does the system run in parallel with the heater core.
can i loop the return right back to the filter?
thanks
thanks
