Matrix37495
The Amish Wolfman
Who has done this and how much header wrap did you use? Any tips for someone who has never done it?
That seems to make sense.to my limited understanding, rusted pipes isn't a problem as long as you get the pipes hot enough to completely evaporate any moisture... I was reading a thread on that subject a while back when I went through over 100 pages of threads on here.
Yep, forgot about that.Wouldn't it be better to have it ceramic coated?
I've wrapped the crossover, up-pipe, and downpipe on my crew cab. I have the same turbo on my F250, as well as the same pump and injectors (all Moose). The wrapped pipes makes a significant improvment in spool time. I don't drive that rig at all during winter months so I'm not worried about salt/water being trapped in the wrap.
I bought one 50 foot roll and several packs of stainless ties to hold it on.
Best tip.......... soak it in a bucket of water before applying. It is so much easier to use when wet. Allow it to dry completely and then install.
Heath
