AmericanMade97
Hey guys I have a friend that is looking to make WMO and run it in his 6.0L it is an '04. 1 is this a good idea and if so can you give me some ideas on mixes. Thanks
DO NOT RUN ANYTHING EXCEPT PUMP DIESEL in a 6.0!!!!!!!!!!!
A load of bad pump diesel can kill injectors in a 6.0, and injectors are not cheap. A full set if you kill them is ~$1600 if you can find a deal. Not worth the trouble it can cause. Also... the way the computer is tuned, it cannot run over 20% non diesel (bio or W?O), because of the emission systems and tuning. Again, not my truck..... but I have a 6.0 and will never run anything but pump diesel, and a bit of power service in it..... ever!!!!!!
The 7.3 PSD is more tolerant than the 6.0, 6.4 or 6.7's...... I know from the factory the primary filter on a 6.0 is 10micron, and the secondary, engine mounted filter is 4 microns..... so the injectors are very sensitive!!!!!
would you say that the older 7.3s are more tolerant or just 7.3s in general
If the oil is clean, the 6.9-7.3 are pretty tolerant of the stuff. The 7.3 powerstroke works good and even starts good on the stuff. It just has to be clean.
