WMO in CRD, Test in progress - any others using WMO in CRD?
janssen
Ontario/Canada
I use WMO exclusively for years now in all my mechanical diesels. Blend is 85%. Love it. In Northern Canada runs great in the winter at -40 no preheaters, same blend.
In beginning had trouble due to not clean enough, plugged some injectors. invested in a bowl centrifuge and never looked back, fuge it, blend it, fuge it again. fug'ing at rate 5 days for 1000/L
Am currently running a "destruction test" in my old test 470K 2008 Jeep Grand Cherokee with the Mercedes 3.0 CRD. at 3500 kms and no issues, took a few tanks for the computer to readjust in beginning smoked blue on idle like a ******! only difference i see now is that I roll some coal when accelerating hard. Only mods is hot chipped from GDE, DPF delete and 1~mic absolute inline filter before factory filter. Also drive it like a stole it - but that is normal :)
Am pretty optimistic at this point in the CRD test.
To the pessimists - Yes I know wmo has sharp little carbon thingys and will wear injectors faster, that is what parts vehicles are for!
All figures involve some rounding to make numbers easier.
So 3500Km = ~2200miles
17mpg (remember the drive it like you stole it)
2200/17 = ~130 gallons used
Canada - $4.58/gallon (1.20L) ( we carbon tax our fuel to save the environment!! - not sure how that works but been assured by my betters it does)
I figure it costs me .20/L or .76/Gallon to make (paying myself $0.05L $0.19/Gallon for hauling/pumping oil, some capital costs included, trucking, centrifuge etc.. not free)
I save 3.79/gallon
So current savings 492.44 in the last 6 weeks. $82/week, $4264 a year
Paid $3000 for the jeep. Current ~200K jeep CRD prices ~$7500
If this works then I will pour it into my wife's nice, $16K, low mileage jeep and she does about double my mileage so $8528 a year savings in hers + 4264 savings in mine $12,792 savings in fuel a year for this family JUST in our daily drivers. Not including farm tractors.
I can buy 1 "new" jeep every year if I have too and still be ahead...
Am I willing to risk it? So far I think yes...
bbjordan
Snow Monkey
Ashern Manitoba
Good stuff! Good to see it runs ok @ -40C. I've run into problems around -10C with my mix: 85% WMO, 10%RUG and 5% Biodiesel (for lubricity). It would appear that perhaps the biodiesel is causing the problems. I know it gels at -6C.
Are your calcs using Imperial gallons or US gallons?
Avoid confusion, use Metric units. ;PokeLOL:angel:
janssen
Ontario/Canada
There was alot of rounding in my conversion calcs, Her majesty would be disappointed in me as I used US gallons from those ungrateful colonies :)
Why would you use biodiesel for lubricity? lots of guys add some atf to their regular diesel for lubricity and we are running 85% old oil - lots of lubricity! Even some nice carbon chunks to cut polish the internals :)
Jeep is in getting a new set of glow plugs right now (I am lazy) and the mech is going to take a peek with his fibre camera and see how bad the coking is. I am quite interested in the results.
Might start running a can of Sea Foam through every 5 tanks or so.
Pretty impressed how the ECM is adjusting for the wmo, smoked like a ****** when I started - now only rolling some coal on acceleration and that seems to be decreasing as well.
janssen
Ontario/Canada
Update - so ran about 7K so far and all is good - except one small issue. I wont start worth a crap on straight W85 tip start takes 3 trys, so switched to reg diesel and problem went away instantly.
Working on blending w85 with diesel and see how little I can use before starting gets bad. Also going to setup my glow plugs on a pushbutton and see if running longer works.
thx JJ
bbjordan
Snow Monkey
Ashern Manitoba
I should have said I add biodiesel as a cetane enhancer, as well.
I normally add 2 liters to my rear tank of #2 diesel for lubricity & cetane booster.
This last weekend I took a 780 km trip using a blend of:
75% WMO
11% RUG
4% Biodiesel
10% Diesel
The 7.3 PSD ran great!
Vikingtrad3r
TukToyYukYuk
thx JJ
Any new updates on how the mercedes engine is holding up to the alternative fuels?
Clb
Another old truck
nannyfornia
Great tech looks like a good start for a tech 101 submission.
Dis here's our flag ...;Poke
