Damn Billy, get them pics up!
Dave, how well does that Isuzu PS pump work in terms of flow? What kind of filtering setup are you running?
My pump will works pretty good even with cold oil. At around 20 degrees F, it takes about 20 minutes to move 55 gallons of straight used 15-40.
On initial pump out into my storage tanks, I have been using The primary and secondary filters off a Detroit 6-71. I found the bases on a junk engine and bought the filters new. Cost: about $20.
Primary 33118 (30 micron)
http://www.wixfilters.com/filterlookup/PartDetail.asp?Part=33118
Secondary 33120 (10 micron)
http://www.wixfilters.com/filterlookup/PartDetail.asp?Part=33120
Once the wmo is in my containers at home, I mix in 15% reg unleaded and stir by letting my pump suck off the top off the barrel with the outlet placed in the bottom of the barrel. I let that go on for about 30 minutes. The gas really makes the oil flow alot better.
Next, I attach 2 home depot water filters, 5 micron and 1 micron. I then pump it into the final stage drum for use in my "offroad only vehicle".
I need a lower volume pump on my setup for when I go thru the 5 and 1 micron filters. They do not flow enough and my big pump gets hot, so I have to cycle it. I am thinking of buying one of those little green diesel pumps from Advaned Auto for the final stage.
http://shop.advanceautoparts.com/we...EL-Mr--Gasket_6340003-P_N3339K_P|GRP2030P____
It would take a while but since I am pumping from 1 55 gal drum into another 55 gal drum, I would not have to watch it that closely.
