First of all thanks to all the tech gurus and their input on my thread concerning my 6.9 running rough and blowing a ton of white smoke. But the source of the problem was not anything mentioned. I had a theory, sprouted from the fact that my exhaust manifold had oil seeping from cylinder #1, and oil was drizzling down my down pipe (ATS 088 slip fit). I pulled the glow plug from #1 and turned the engine over with my finger over the hole. Vacuum. And when the piston came back up it didn't blow my finger off. Valve train issue for sure. So I pulled the valve cover, and lone behold, a bolt had backed out of the rocker arm assembly! So I tightened it back up and the rocker was still loose. Hmmm. I took the rockers out and checked the pushrods on glass and they checked out good. Put a set of 7.3 rockers I had gotten from the junkyard, and they tightened down nicely. Bent rocker arm. Really? This whole time it was that simple?!! Intake valve wasn't functioning so the cylinder was sucking oil through the valve guides, Just like I had thought. Needless to say, I'm pretty stoked that my truck can now be driven!
