Hey Bucholzi, if your starter is sticking on like mine did brand new out of the box it is a very easy fix, Take off the solenoid end with the 3 little philips screw heads and wire conections on it, you will see a washer on a shaft pushed up by a spring in there, sand both contact surfaces smooth again, and put it back together. They are doing something wrong at the factory when they are tested as my washers were welded together, that doesn't just happen passing regular current through it, atleast I don't think so.
