performancelaw
What size tire can I run with out rubbing to reduce my rpms a little. 45 with od is 2500 is. 2200 ish with od @ 60 ish.
235/85R16's in the rear is the biggest. I'm assuming right now you've got 215/85R16's. If so, you've got 30.4" tires, 235's are 31.7" tires. That's 4.4%, or 2200 rpm's becomes 2103 rpms.
Toyo makes a 255/85r16 which is about 34" tall. They wear like iron and it shows in their price. Look at the M55 commercial tire lineup. Your truck is 2wd?? Don't think you will be stuffing these up front on a stock vehicle. Good luck
