The shaft is a different diameter and the two will not interchange.
that's good to know it can be doneI'll add this... The V belt pumps have the mounting holes threaded in them. The serpentine belt setups don't. The clocking of the vacuum nipple is differant too but you can make either one work on the other motors. I know nothing about the shafts being larger or smaller. I did use the v belt pump on my serpentine motor after I drilled out the mounting holes threads. The serpentine pulley fit it fine.... So now thats got some confused... any other imput....![]()
