Facet pump problem?
abfiegen
United States
I know there are numerous posts regarding this but none seemed quite as extreme as my situation. I removed and cleaned filter and bowl on my lift pump cause I was having hard starts and found it to be pretty nasty. I refilled bowl with diesel Kleen and reinstalled. Started right up easy as I could remember in a long time. Let it idle for a while. After probably 10-15 minutes I returned. It was still running well but I noticed the bowl was only 1/3-1/2 full. Seems like an indication the pump isn’t keeping up. But like I said truck sounded totally normal so I’m not sure if I’m imagining a problem or it’s a real one. Thanks for any help!
Clb
Another old truck
nannyfornia
Pretty sure they run like that normally, I'll try to get a pic of my slow *** transfer tank for you later...
ROCK HARVEY
Dayton OH
I wonder if the bowl gasket is leaking and causing it to suck air. You can buy replacement gaskets if it’s cracked, but I would start by making sure the bowl is tight. If you’re getting enough debris in the screen to clog it, it’s probably time to clean out your fuel tanks.
DirtyWood
Earth
I had some performance issues with the facet pump but was able to increase the fuel pressure about 1-2 psi simply by blowing out the fuel lines with low-psi compressed air. I think I used about 15psi, disconnected the inlet line at the Facet pump and pushed air back through both tanks--remember to remove the fuel tank caps before doing this. My fuel pressure gauge showed a consistent increase in pressure.
Greenbullnose
