dyingtolive04
Good evening all.
I recently purchased and installed a Facet 40290 on my new-to-me '93 F350 with a 7.3 IDIT. The truck was somewhat of a basketcase when I got it, and I've been trying to work through all the issues to get it to daily driveable status. One of the issues I had was that my fuel filter restriction light was coming on while driving at anything over 25%ish throttle. Much reading on the forums suggested a Facet lift pump, either the 40222 or 40290 variety. The hot rodder in me said to spring for the higher pressure/flow pump and use a bypass regulator to bring it down to acceptable pressures, so that's what I did. I ran hard-tube adapter fittings to run -6AN hose from the frame rail to the pump. Fuel comes out of the pump and into the filter head. From the filter head it goes into the regulator, and from the regulator, it runs to another -6 to 5/16 hard tube adapter into the injection pump. The bypass/return runs off of the regulator and T's into the return line off the back of the engine. My thought in running the regulator between the filter head and the IP was so that I could still use the Schrader valve on the filter head to bleed air on priming- which worked great! My problem is that according to the gauge mounted on the regulator, I'm seeing no more than 8psi of pressure regardless of regulator adjustment, which is fine by me. The issue is that as soon as I crank the truck, fuel pressure drops to zero on said gauge, and the bowl on the pump is almost empty. Perhaps I'm not quite understanding how this assembly works, but it would seem to me that if my regulator is bottomed out and seeing 8psi, I'd still see 8psi at idle, no? Pressure stays a constant zero at idle regardless of whether the bypass/return off the regulator is blocked/pinched off or not.... Am I missing something here? Or did I screw something up? Thank you in advance
