crewchief219
I had a slight shake above 50 mph so I replaced both u joints with off the shelf ujoints. Got a little better but blew the rear out.. and then again.. learned my lesson and got Spicer ujoints and also had the driveshaft balanced. Now its super smooth. But heres my problem:
I want to make sure ive got a good fix, the only thing holding me up is the fact that when I installed the driveshaft, there was a little play between the caps and the tabs on the rear axle yoke that hold the ujoint centered in place. Its only a small amount, and im sure they're the right ujoints, so when I installed it I made sure the caps were both fully seated on the ujoint and tightened it down. I checked after a couple days of driving and the caps have worked their way out and now I can move the driveshaft again. Still no vibration that I can feel, but is this normal?
Driveshaft was balanced and Spicer ujoints were installed by machine shop. All I did was intall the driveshaft.
