Hi Gang!
Turbo is in and running, everything looks good so far except for the blasted CDR valve cover is leaking! I cleaned the head and cover meticulously and used high temperature permatex on the valve cover side, letting it tack before installing the new Felpro rubber gasket. I installed it on the head, evenly lightly snugged and torqued it in three steps the next day. I can't understand why it's leaking, the cover looked good and I did everything correctly. Do you think that retorquing it is worth a shot? What about pulling it and if the gasket is adhered to the cover, cleaning it and the head and using permatex on the head side as well?
Many thanks!
Many thanks!
