94 7.3T Valve cover swap
GRY9273IDI
florida
is it possible to swap the valve covers on a 1994 7.3T with a set off a 92 N/A 7.3? I was reading through some tech pubs and saw that the design was changed but none of the changes were listed for performance. I personally like the glow plug relay not on the valve cover and my set off my 92 are in better shape than the ones on my 94.
Yes. The only changes were to the top of the valve covers. In order for them not to bolt on, they would have had to change the heads. That wouldn't make sense for the limited number of trucks with the optional turbo and they also knew that the IDI was coming to the end of it's run, so there's no reason to change anything like the heads.
Oiler
