WhistlinDiesel
Hi, I was wondering if there is any way to get a tuner or better MPG with my 92 7.3 IDI? It is a crew cab dually, Thank yall
The GV doesn`t give you any boost, It can be mounted behind any transmission. Auto or manual. Once you are in high gear, put the GV in the OD position and you have one higher gear than the 1:1.I know with the c6 you can do a gear vendor I was told you get a small boost other than that no clue I'm learning these things still.
When they were new, the codes on the sides of the injectors may have meant something, but these days, after being rebuilt multiple times, the letter codes mean nothing. Just go with one of the supplies that Old Goat mentioned.Is there any injectors that would be better than others?
I think that he meant that a Gear Vendors will give you a slight boost in mileage. He just didn't quite add all of the words.The GV doesn`t give you any boost,
This is probably the best advice that you can follow. 20= years ago, I knew an older guy who swore that he got 23 MPG out of his 89 F250 Ex. cab, E4OD, 4X2. I was told by someone else that it probably took him 2 miles to get up to 60 MPH and that's probably all the faster that he drove even on the interstates.Don`r race every one to the next red light. Drive like you have an egg under your foot.
I completely understand that...This is probably the best advice that you can follow. 20= years ago, I knew an older guy who swore that he got 23 MPG out of his 89 F250 Ex. cab, E4OD, 4X2. I was told by someone else that it probably took him 2 miles to get up to 60 MPH and that's probably all the faster that he drove even on the interstates.
As for me, I don't try racing anyone to the next red light. I also don't try to set any acceleration records while getting onto the highway. My problem is that I don't drive down the highway like there's an egg under my foot. I HATE losing speed up hills. I probably need to work on that one.
I drive my IDIs like a 2 stroke Detroit ( slam your fingers in the door and floor it),
No it wouldn't be. The last 460 I drove got better than that empty.because 10 mpg ain't no fun.........
When you have to do all of this, I doubt that there's much that you can do to improve your mileage.Then again, they get get worked between 4 farms, very hilly country, they idle a lot, the hubs are always in, and the winter blend fuel don't help...
