trucks just not the same
Will
louisville ky
i had ip pump put on now the power is just the same as it was befor. what to do about that?? also the cold start is not working right plunger is no where to where it was befor
91idi
Fiberglass *****
X
Needs timed would be my guess. Who serviced the pump
'94IDITurbo7.3
HAMMER DOWN!
Fowlerville Michigan
like asked above, where did you get the pump from. when i put a "new" pump on my truck i never got the "holy new IP batman" feeling. turns out i got a POS rebuild.
Devon Harley
San Diego
Bad timming would be my guess most don't think you have to time cause factory spec is 2 degrees off of correct or it can they say I found it should be set right if your want power an mpg.
Will
louisville ky
it is a rebuild pump and no they did not reset the timeing. i asked them when i picked the truck up adavanced mechanical here in town.i drive maybe 8 to 9 miles to work if that i put 20 bucks in the truck that is 5 gal or right at it. two days and tank was dry. guess its going back to the shop
Clearly the timing is retarded. If they timed it you need to ask how they did it. Some are telling us they do it by ear... Thats not going to work at all. Some use the luminosity probe methos and most here will use the clampon timing probe which has been about the fastest and bestos way of timing these engines by far.
redneckaggie
rebel w/o a cause
angleton/stephenville tx
what plunger are you talking about, the one that controls idle can be adjusted, If the pump was installed it needs timed, lineing up the factory marks will not tell you anything
Why did you replace the ip?
Will
louisville ky
the plunger thing on the cold start to the ip. a shop here in town put the pump on
redneckaggie
rebel w/o a cause
there are two plunger things in the cold start circuit one is on the driver side and the other is towards the fan on the front side. again why was the pump replaced
Will
louisville ky
one on the passnger side old pump was leaking fule bad will take pics when i get off work
91idi
Fiberglass *****
X
I'll ask my grandpa who he uses for his pumps. He has his rebuilt in Louisville and has really good luck.
hesutton
The Anti-Anderson
Bowling Green, KY
Probably Diesel Injection Service.
Likely timing as stated, but, how about the injectors?
I'm going to host a mini IDI meet at this year's TS Performace Diesel Outlaw event here in Bowling Green. Gary (icanfixall) has generously offered a timing meter for use at this mini meet. I've used them before and we could certainly time it then. But, that's not until May. Regardless, I'd love to meet you there and see your rig.
Heath
Will
louisville ky
[/IMG]
what is this and what's it for??
[/IMG]
[/IMG]
testing
