00 ring terminalwhat is the actual terminology for that?
"00" is the wire size
can you post a pic of what you got?I'll make sure to get a higher gauge so this one doesn't just fall apart, I think thats why the first time it burnt up someone used a smaller gauge....
If you are going to solder it on, get a propane torch. Unless you have a soldering iron that is industrial, heavy duty, huge. A propane torch works great and is quick. Heat the terminal itself, push the solder into the wire and fill the "cup" of the terminal. let it cool and then cover the burnt insulation, exposed wire, solder, and part of the terminal with a length of heat shrink.
its ford service approved
punk
the one I have is actually with my step dad to go pick up the part I told him to the 00 gauge....
