ColLonewolf
Looking at a 2006 F650 with a c-7 cat and an Eaton fuller 6 speed. Any chance this 6 speed would bolt to a 7.3L IDI? Thanks.
That's a bit stout for my needs. Thanks for keeping me in mind though, @Nero ! I do know where some school buses are with Allisons on Navistars. I wanted to do a 4speed Allison one time, but I couldn't come up with the correct adapter thingy, and then I scored the ZF5.Here's an option.
IHC/Spicer 5 Speed Transmission - auto parts - by owner - vehicle...
I no longer have need of this transmission. It is a Spicer ES-42-5A model with the matching SAE#2 engine adapter, clutch parts, and starter. It came out of an old international truck with a 6.9 IDI...portland.craigslist.org
If not, @Jesus Freak should come get it
I believe that just means you install it and forget about it, right?That's a bit stout for my needs.
It's multifaceted:I believe that just means you install it and forget about it, right?
That would be quite a haul to pick it up though.
James
Probably came out of a 2 1 /2 ton truck, a 1600 model. Some of the larger U Hauls (Yall Haul in the south) were 1600`s and think they used the 6.9 engine.....but U Haul most likely used an auto trans.That's a bit stout for my needs. Thanks for keeping me in mind though, @Nero ! I do know where some school buses are with Allisons on Navistars. I wanted to do a 4speed Allison one time, but I couldn't come up with the correct adapter thingy, and then I scored the ZF5.
