Waystro
No Class
Looks like you need a new radiator
I'm Running a Genesis all aluminum Raditator in my Suburban
Have you bypassed the trans cooler in the radiator?
From the factory you have at least one line going into a heat exchanger built into the bottom radiator tank. If the truck doesn't have tow-package then the other line is also hooked up to it, basically fluid comes out the trans, runs thru the in-radiator cooler, and goes back into the trans. If truck has the tow package then the 2nd transmission cooling line doesn't hook up to the in-radiator cooler, instead there is an external cooler on the front of the radiator - you have a hose running between the in-radiator cooler and the external one, and then another hose running between the external cooler and the 2nd transmission cooling line. Is this how your coolers are set up?Personally, no. All I know is that the trans cooler hose goes to the metal trans lines. I don't think anything is connected to the rad, but I'll look tomorrow.
Would I have to bypass even if I had an external cooler?
If you only have the external cooler and the in-radiator one is completely bypassed then you should not have any leaks from the in-radiator one cause there's no fluid flowing thru it. Unless it was full of fluid this whole time from back when it was still in use, and for whatever reasons it is now leaking said fluid out - but they don't hold much fluid, so whatever was in there is by now out and on the ground...
Don't bypass that cooler. Get it fixed, or replace the radiator.
Just to recap, which lines, if any, have you replaced?
