gandalf
Senior Member
Just a quick thought in passing. It may not be worth anything, but it occurred to me as I was reading.
You said molten solder? As in it was stuck to the pan? For that to happen wouldn't it have had to drop onto the pan still in a molten state? I can't think of any other way, offhand. But, if it is inside a hot running transmission, wouldn't it have to drop through the ATF first? Wouldn't that pretty well kill any molten state? If we start with that theory, and the solder truly hit in a molten state, then it must have done so when the pan was not on the transmission. Take a very close and careful look at how that solder is attached to the pan.
Does this make sense?
