Ataylor
I'm going to drill my manifold tonight and was wondering if anyone had any tips for drilling into cast iron.
I'm planning to drill into the top of the driver side manifold between the back two cylinders. From the research that looks like the common spot. It is also as far back as I can get on the manifold since I have automatic tran linkage in the way. Is this the thickest spot to tap?
I'm going to center punch, then drill with a cobalt 1/8", then 1/4", then letter "R", then tap with 1/8" 27 pipe thread tap. I was going to use Rapid Tap fluid for drilling and tapping.
My biggest concern is getting the thickest spot to drill and tap.
Also, from looking around on the internet I read that you don't need to use a lubricant for cast iron. Does that sound right? I figured it can't hurt to use some when drilling, but not sure.
Thanks for any tips anyone can offer,
Archie
Archie
