timing???
Cant tell without a meter...
Rent Garys meter...check make informed decisions
Then dont **** around take the time to solve the issue correctly aligning timing marks.
turbo elk
Vancouver, Wa.
Does anybody think it would do damage to drive it 50 or 60 miles?
It seems that the engine temperature comes up a little faster and it runs a little warmer than normal.
turbo elk
Vancouver, Wa.
I guess I should not have asked which way to turn the gear to advance it but which way is normal rotation?
Clb
Another old truck
nannyfornia
Leaning the top of it (pump)to pass side =advancing it
turbo elk
Vancouver, Wa.
So.... I was 1 tooth off, retarded, I got my fuel leak fixed, hopefully its not leaking oil anymore (or it's slowed down a lot) thank you to everyone who gave me help and hints.
Hope it passes DEQ tomorrow.
its very easy to tell yourself that you have done this correct.
hard headed individuals need to find out for sure.
(like the both of us)
lesson learned, hope it goes well.
rent a meter! it does make all the difference!
trust me, ive been in your shoes.
turbo elk
Vancouver, Wa.
Thanks Russ.... I work Thursday thru Thursday
IDIoit, what, me hard headed? You can ask my wife of 26 years and I'm POSITIVE she would tell you that I'm not a bit hard headed... not even a tiny bit.
I'm positive.
I actually thought it was a tooth advanced.
turbo elk
Vancouver, Wa.
So I just went through DEQ and passed, but they did not give me an Opacity reading. but it runs alot better, now I've got to get it timed.
Clb
Another old truck
nannyfornia
Congrats on passing
pwillis
