because a mottor need three things to run right air fuel and combstion i know it geting are and fuel so that leads me to combstion
I work on diesel engines for a living, I appreciate you trying to teach me something in a thread that you started over an engine you are incapable of getting to run. You are however somewhat off in your view of the situation however.
You need
1. Fuel
2. Air
3. Ignition
you claim to have 1 and 2. So that leaves #3
You claim that in California you do not need a block heater.... I beg to differ. If you cannot get the glowplugs to work you need some sort of starting aid. I live in South Georgia which stays pretty hot. We had a truck that didn't have a functioning glowplug system. On 100 degree days in the summer it did not fire readily unless plugged in. After we got it to fire off it was fine for the day, but the first cold fire is a little ******* these old guys.
If I recall I spent about $5 to wire the glowplugs to come on manually. Buy a set of glowplugs and move on.
So.... from someone that *might* know a little more about engines than you:
When you encounter an engine. You do a fact finding mission. Armed with this information you make a list of the most likely problems to the least likely and work your way through them.
Everyone in this thread has done this but you. We have all screamed that the first thing you need to do is get the glowplugs working (or any starting aid really). You have pretty much flat out refused to do this for some reason.
So I have to ask... why the hell are you here?
