Light a fire under the oil pan.
Okay, so far from what I've read, batteries are either out or are pretty much out, your glowplugs you claim are shot, you have smoke (indicating fuel into cylinder) but you seem to just be jumping around. Start with what you know is wrong, batteries..... replace them, then cranking speed, then glowplugs. I don't see where you have any evidence your ip took a dump. Could it be? Maybe, but all troubleshooting starts with what you know is wrong that is contributing to your no start, fixing that, then moving on. You mentioned ether, did it huff at all? If its cranking too slow, I don't know that even with it the motor would catch. Start with the basics, post results, go from there. I realize this has been said, but please try to make your posts legible, its very difficult for us to help if we struggle to reae what you have posted.
I don't get it. you said the glow plugs don't work. You are having trouble starting the truck.
so you think it is the rings, ip, etc? on what basis?
Just to clarify, you cracked the lines and bled the air out at the injectors?
