Midwest_Mudder
did your truck not have a block heater? or?
First off this is a slightly dangerous method but alot easier on the engine than ether is. First make sure you have fuel at the injectors by cracking a couple lines and spinning it over. If there is fuel then take a shop rag and wet it down good with gasoline. Lay the wet area over the intake screen. Try to crank it up. I've had diesels that would start no matter what fire up with this trick.
If it's cranking normal and not catching with ether your F'ed. Doesn't need fuel in the injectors to get it to fire off with ether, ether alone should get it to catch for a split second. If it's not, something internal is screwy.
How much ether are you giving it?
Why? You don't have a screen over your intake opening also? I have also done this by stuffing the rag into the air cleaner housings neck.
On my current truck, no the screen was missing when I got the truck.
But even with the screen, when it starts it's pulling those fumes into a running engine. That can't be good for it.
Won't hurt a damn thing, gas evaporates pretty quick.
