It is a fair question to ask. There is some parts substitution, some machining, and a lot of tweaking that goes on. I suppose if you were a dedicated individual, you could sit down with a Moose Pump and a stock one, get out your micrometer, your dial caliper, your pantograph, and commence to taking both apart, comparing every part until you arrived at the sum of all the changes. Then you could try and make your own, but you still wouldn't have the knowledge of how to calibrate it, and since every pump is just a hair different, you can't really count the number of turns of a given screw or fitting to arrive at an identical unit. That's all I can tell you, because I don't personally do them. That's done by a mad scientist in a secret lab that only I know about.
. But I can tell you that this person knows what you say about him, likes his work, and likes hearing that you guys are happy with the fruits of his labor. I myself, along with many here, have taken pumps apart, and tried playing with the settings and seeing what happens. If you ever get one all the way apart, you know they have a lot of little pieces, and a lot of precision fit parts. Just like a vehicle windsheild, on the surface it all looks real easy, but once you get into it, suddenly your lack of knowledge, resources, and tools, becomes a buggaboo to deal with, and the problems can come faster than the solutions. I'll have a Moose Pump for sale at the rally. If someone wants to buy it and take it apart right there, I'm all for it! Then we can see whats inside.
Oh, but the warranty ends with the sale then.
