swapping E4OD linkage?
BIG DAVE
OILBURNER FOR LIFE!
kenai alaska
How do I get these off so i can swap them over?
My new(to me) tranny is out of a 91 and here's the linkage (I don't know how to take it off)cookoo
I need this one for my 92
Thanks for any help;Sweet
J D Recovery
Street, MD
are they the same trans? The lower one looks like my e4od and the top looks like a aod not sure tho.
I think your out of luck. From the pics I see no way of changing these levers unless you open up the trans. Sorry....
david85
Campbell River, B.C.
Pan has to drop to swap the levers. There will be a nut on the insude and a dowel pin that has to be pulled out the through the pan gasket mating surface.
You will need a special hardened hook to pull that pin out (or make something if you can).
http://www.thedieselgarage.com/projects/e4od/
