I enjoy Reading this site every night as part of my night time fun. As a professional Tech I can say you never stop learning from others and I have learned so much from you all on this site. My problem is this. I have owned this truck, a 1987 CC Dually 6.9 4.10 LS rear end. I am working toward a full restoration. Today I thought I would do a fluid change to the rear. When I dropped the cover off I noticed some large metal pieces laying in the bottom. Hmmm, what could this be??? Now I have set up many rears over the years and was shocked to realize that those very large pieces were from the pinion gear!! Keep in mind this truck drives great,no gear noise what so ever under acceleration or coast talk about a fluke. I tow a 28ft 17k loaded enclosed car trailer with this thing from time to time!! I can only imagine how lucky I am that nothing bad happened. Everything is tight and the comon loose pinion nut is not the problem and all else is fine. Have any of you ever run into a weakness in our pinion gears? Anyway now I need to find a good set of 4.10s and while it's down maybe rebuild the posi unit since I'm in there now.....Appreciate any thoughts/suggestions inexpensive upgrades you might have.
