Mad Maxine
I'm pulling my tanks out and replacing a sending unit in one and doing a showerhead mod in both. I'm also either going to go with a 38 gallon rear tank and do away with the dual tanks, or replace the fuel control valve and put both tanks back in. I haven't decided yet.
While I have all this apart, I was wondering if it's better to go back with the stock nylon lines and connectors or to go to rubber lines with hose clamps. Do the nylon line connectors seal OK over time, or am I inviting an air leak by continuing to use them?
If I do go back with the nylon lines and connectors at the tank(s), I'll have to modify the other ends for the fuel selector valve since the replacements only have hose barbs and not the connector barbs. Any suggestions as to how to splice the nylon line with a rubber line?
Thanks much!
Thanks much!
