TheRadBaron
I’m rebuilding and modifying the entire fuel system on my ‘94 IDI-T.
I’ll be using an electric fuel pump and doing away with the engine mounted fuel filter.
I’m working on installing the billet fuel return rails from R&D and I’m not sure about the best way to route the lines. Here’s my first idea.
It’s been suggested that I need to use a check valve on the way back to the tank to prevent drainback, and that the brass 90 at the back of the engine on the drivers side has a check valve.
I’ve gotten some other opinions that suggest that the return system needs to be plumbed “in series” to allow all injectors to return properly. I don’t *think* this is the case but I could be wrong. I don’t remember the factory setup being plumbed that way and if it is necessary I can’t see what the optional fittings in the middle of the rails would be used for.
What do you guys think?
I’m trying to keep the hoses and fittings to a minimum for the sake of simplicity and less potential for leaks.
