PwrSmoke
Some years ago, 2006 to be exact, the OE style water separator on my '86 failed (again) so I went to an alternative, the Stanadyne Fuel Minder 100 (google it). It's a 30 micron primary filter that is also a water separator. The version I got came with a water bowl in the bottom but not all of them have this feature. It bolted up in the same spot as the old setup (same holes even) and the only thing missing is the water sensor. I can live with that since in 20 years of the original setup, the light never went off and I never had enough water to worry about. I had no occasion to be unhappy until yesterday.
I had noticed some light surging and since this filter was due for replacement, I went after it. In theory it's a 10 minute job to replace it. In practice it took me about three hours. The filter is a push-on job with a retaining ring that holds in in place. Remove the ring, pull the filter down, unscrew the bowl from the bottom, drain it, clean it, install the bowl on the new filter, push the filter into the housing, install the retainer, bleed it and go. Not so fast bucko! The filter wouldn't come out the the housing. After screwing around about 30 minutes, I removed the assembly and tried with it in the vice. Turns out the filter is steel and the housing is aluminum or some alloy and the two dissimilar metals had mated and refused to divorce. I had to be careful so as not to break the housing but finally it came out. I cleaned up the housing and tried to install the new fitler. Again, no go. It turns out that despite what the books say, the Napa 3638 fuel fitler is not a direct crossover for the Stanadyne 31865 so I had to make a parts run. Worse, I've had the Napa filter around for a few years, so I can't return it.
Turns out both of the new filters had bare steel at the top where the corrosion occurred so I think a coat of antisieze is in order. If you look at current pics of the 31865, that part is painted, which would do the same thing as antisieze. So, if you have one of these filters and it hasn't been out for a while, look for line of rust where the edge of the filter meets the housing (collar removed). If you have filters with bare metal where it inserts into the housing, slobber it up with antisieze.
