Thewespaul
Bulverde, Texas
Last night I finished porting the heads on my 7.3. This morning I took them to a machine shop. I spent about 15 minutes talking about valve recession and other tolerances. He seemed like he understood, but I guess I'll see. I know it wasn't my whole truck, but at least it was PART of it.
What all did you port? The exhaust side is what I've seen needed the most
Definitely! I just gasket matched the ports. The intake needs up to 1/16" taken off about halfway around to match. The exhaust needed up to 1/4" in places. I only went in about 2 to 2 1/2" during the reshaping. The rest I just tried to get rid of the casting marks and smooth the rest of the port out. I also polished (to the best of my ability) everything I could reach. I took new valves, seals, Comp 910 springs, and a piece of paper with the recession specs written down to leave with the machinist. He's going to install new bronze guides and check out the seats.
Sidewinded_idi
Yucaipa ca
Set up my fuel for a family trip this weekend. I run w85 (waste motor oil and gasoline) so I'm bringing 130 gallons with me to make the drive without having to stop!
FORDF250HDXLT
Maine & Oklahoma
Threw some brake shoes on chip truck.Replaced the broken glove box in the accord.Touched up the wood chipper with a couple more bottles of bed liner since I had some welding work done to it so it no longer has gray primer spots.
chillman88
Central NY
Hauled my buddy's Dakota to another mud bog. She ran a little warm so I might have to look into that...
No issues though!
catbird7
PA
Skeleton pretty much picked clean then power washed. Ended up buying a set of replacement wangkung front fenders. Considering powder coating them with zinc rich primer and then picking a "red" that closely matches final paint (canyon red). Considering this in an attempt to provide better corrosion resistance. I'm unsure about powder coating over an unknown primer and there's no way to remove factory primer down inside fenders..... Any opinions on powder coating over this paint? They list coating as electrostatic paint system.....
VandalS
California
Raised the rear bumper 3 inches, swapped in a clean set of mirrors and finishing up the bed.
Seventh
NorCal
Put in a new VSS today after losing Speedo the other day, abs light, flashing od light, terrible shifting.
All is well now
After lunch jumped on the pass side...bit smaller patch but wee bit more repair on inner panel I think.
Did a sligtly larger patch panel will trim to size later...more to come when gst primer...this is it for now.
Thanms for looking.
chillman88
Central NY
Well Friday I did the pivot bushings and added some gear oil to the rear, still need to change that...
Today I changed a radius arm bushing, repacked a wheel bearing, painted the hub while it was off, changed the steering column, and did an oil change. Oh, and ordered a new rear u-joint.
Busy busy busy!
Seventh
NorCal
Swapped out my crusty 7 year old 675cca batteries for some new Duracell ultra 850cca batteries
Moar electrons
Mr Clickety Clackety
California
Yesterday: Removed the blower motor and heater core from both trucks. swapped over the evaporator cuz I mangled the line on Donna
Swapped the seat bottom cushion and fabric from the bench I purchased.
Removed from Ole blue: all belts, ac compressor, vacuum pump, alt, passenger wheel well, pushed aside ps pum and a few brackets.
tke395
