TWeatherford
At least he's not going the other way, leaves a nice mark.
Nothing like a bunch of 2x4s and plywood nailed together acting as a spacer between the bed floor and slide in! I've seen it a few times...
Four good 235/85-16E tires on your rear axle can safely support a 3000 lbs camper, I know that from experience. The more important question is what wheels are said tires currently mounted on, in other words is your truck a 2wd? 2wd dually wheels are designed with 215/85-16 tires in mind, upgrade them with some nice 235-wide A/T tires and all of sudden the tire sidewalls get a bit too close for comfort. At least this is what I experienced.Hey Black Dawg, That is good to hear about the 235/85's that is the sized I have. Wow no airbags? Is that an f350 you were running? Dually? Im going to go back to look at the lance 810 this weekend and put it on the truck and see what it looks like.
The cheap solution would be a pair of spacers between the inner and outer wheels, the studs are long enough to safely accommodate 5/16" thick spacers - the lugnuts will thread on fully and there will even be 1 thread sticking out on the studs. You may be able to clear 3/8" spacers as well, but then if my measurements are correct the studs will be 1 thread too short - some may say this is OK, but I wasn't brave enough to try it. Keep in mind that the moment you slide them spacers on the outer wheels become non-hubcentric and as such are a bear to center properly, heck I think I messed up one of mine last time cause now they're good under 60-65mph but try 75 and the shaking begins... One of these days I gotta try running a pair of '94-up (non-coined) Dodge wheels as outers since they have smaller hub openings (4.77" vs. 4.88") and may just be able to pilot on the tapered part of the Ford hub...
The correct solution to the problem is to install dually wheels designed for 235-wide tires, which would be factory wheels for a dually cab-chassis 4x4 truck - those have more offset/backspacing to them, not much (0.35" per wheel, for total of 0.7" or about 18mm), but enough to ensure that sidewalls won't touch unless you severely overload the axle or underinflate the tires. If you wanna buy new you're looking for Accuride #29578 for the 2500lbs/65psi wheel or #29580 for the 2300lbs/80psi wheel. By the way your current wheels are probably rated at 2200lbs and 65psi.
About the airbags, if your rear springs are still the borderline useless 5-leaf main packs with single-leaf overloads and like 2" of clearance between said overloads and their frame brackets, yeah chances are you could use airbags. If you choose to install them, make sure you don't plumb them together, instead give each bag its own fill/dump valve and air line - bags T-eed together can shift air from side to side and don't do much to control sway, while separated bags not only help w/ sway but also allow you to level out your truck if it's heavier to one side. Also, if you drive lots of washboard roads, giving those air bags some ping tanks (google it) may be a real good idea. FWIW my 350 don't have air bags, but leaf packs ain't stock either - with 3k camper loaded the rear ride height drops by about 2-1/2" and the front by only 1/4" if that, and truck is still a good inch from becoming level. I towed a 1-ton diesel CJ on military 36s w/ four wheels down and both transfer cases in neutral, so no tongue weight, but no electric brakes either - no problems whatsoever, altho I gotta admit having camper and jeep on/behind the 600 (think your truck on steroids) feels quite a bit more comforting than using the 350 as a motivator...
So your truck is just a normal 2wd dually 4-door, and Centurion only spiffed it up appearance- and amenities-wise.
+++Yeah, Spiffed up...lol...I wish they hadnt spiffed it up with the "austin" sticker package lol.
This is good, a factory dually truck is more than able to handle a camper like that Lance. Nice camper by the way, that north-south bed will give you all sorts of storage space and "flow" real nice with your long truck cab. If you plan on going camping in winter, you'll find that with good tires your truck becomes almost unstoppable in snow when camper is in the bed (I took mine to the WI mountains this winter, didn't have much issue keeping up w/ the better half's Jeep-thing).
+++oh good to know. So it does well in the snow with all that weight. The limited slip has helped a bit in the past coming out of snowy jeep staging areas.
On the ride height - barely touching the overload is a good and a bad thing, good cause it means you're far from being overloaded, but bad cause when they're barely under load the overloads tend to "kick" more as the suspension cycles. Won't hurt a thing, but may annoy you to death. Since your camper is so light it seems you won't be running much pressure in the air bags, so no ping tanks needed either - less money spend on equipment is more money spend enjoying the outdoors.
+++Thanks that is good to hear. Im just assuming once I have the camper and Trailer/jeep hooked up, I will need the airbags.
On the spacers, go with 5/16 if you can. But load camper back on and check to see what the situation is first, depending on brand and model of tires you may not even need spacers.
+++Cant find any 5/16. So I guess for now Ill just order some 1/4" spacers and see how they do. (BF goodrich "commercial" tires is what i have. 235/85 r16 E)
A heads-up, since I see your remote sitting on the table - someone on one of the RV sites recently reported that when he went to lift his camper to load on truck the remote only powered up one of the four jacks - he caught it on time and no damage was done to camper or jacks, but just keep an eye out. Also when you store camper off truck, make something for it to sit on, it's way more stable in strong winds if the bottom is resting on something solid and jacks are down only to stabilize it. And finally look into a frame-mounted setup for attaching camper to truck, bed tie downs don't work out too great when you start bounding up and down on the two-tracks.
+++All good information thank you. I do like the electric jacks...Im guessing loading and unloading will be a lot quicker with them.
I pack an 11.5 89 lance with the buggy trailer behind it, usually 16.7 k the way the wife loads the camper. I am at max on the tires srw. but it does fine, get a lighter trailer if possible.
http://www.oilburners.net/forums/attachment.php?attachmentid=17806&d=1195426241
