Rebuilding turbo
Idiohmy
Wyomin
Hey, I'm new here and to the idi community. I just purchased a 1990 extended cab from a guy and he had a turbo with it off a 93 or 94, it's a Garrett, the only markings I can remember off the top of my head are Ar 70 or something. Well before I bought it I had already done a little research or what not and decided down the line I would get one of those banks or hypermax turbo kits to put in it.
I guess my question is what are your opinions on rebuilding this factory one and just getting a new exhaust to save a few bucks vs a brand new banks? I'm not trying to pull no crazy numbers on the dino, just a camper up the mountain.
Idiohmy
Wyomin
Oh yeah, here she is. Not a huge fan of the paint or headache/sleeper thing, but this truck is clean inside n out
pelky350
Springfield, OR
I keep getting mixed reviews online of the wicked wheel on the turbos some even said they lost a couple psi of boost? My friend keeps saying that it has a extra fin causing lag and they are not billet but I'm pretty sure he is wrong or maybe it's a different application this may be in, he also owns a Cummins so it's probably different for his truck anyway?
shawn deere
So many wrenches, so little time...
nebraska
Ive heard with the Original WW you lose a little top end boost. I wish i had a good before and after for the WW2... but i have no regrets
shawn deere
nebraska
What you got will be plenty. These engines can only handle 10psi boost max unless you put in head studs.
Now if you put a wicked wheel2 in, new exhaust, and head studs and block off the waste gate it will be an entirely different animal. For $1,000.
I went with a billet wheel for the longevity.
having a cast wheel that spins at 10k+ is not how I like to do things.
ive purchased 2 WWII's and they are billet aluminum.
FYI
Billet = something made out of a single block of metal
no mufflers
rhode island
I have a banks sidewinder for sale soon. only has around 35,000 miles on it. never been in the salty weather.
PM me if interested.
typ4
Newberg,OR
I can rebuild that for you and do some upgrades that will wake it right up.
For what you are doing the factory style turbo kit is just fine. Get everything with it though.
Macrobb
North Idaho
I'm going to tell you right now that you need more fuel. I've run the same pump on both a newer Banks Sidewinder kit(with 3" pipe and glasspack) and a factory turbo setup(with stock 2.25" exhaust minus muffler).
Going from the stock IP to a RD2-110 IP netted me 245-250RWHP on *both* rigs, and they were both pretty clearly turbo-limited.
Still, that's nothing to sneeze at - 320-ish HP at the crank with just a bolt on pump? That's 6.(uhoh) numbers right there!
It certainly makes towing fun, that's for sure. No issues at all hauling 8-9K(another IDI truck on car trailer) at 75MPH.
<_< Still running 15-ish PSI through mine with head bolts. Hasn't failed yet.
IIRC, people say it starts blowing around 20-ish; probably a bit less with more fuel.
shawn deere
nebraska
Good to know! A bit concerned at the longevity of it though? Just wondering, i dont know first hand the limits
Macrobb
North Idaho
That's what I'm trying to find out. I've heard all sorts of things, including that an IDI will blow up once you put any turbo at all on it.
Heck, my '92 Ford manual has a statement on page 1!
Your diesel engine vehicle was not designed for use with an aftermarket (Non-Ford) turbocharger. Installation or use with an aftermarket turbocharger may cause damage to your vehicle's powertrain (engine, transmission, driveline, and drive axle) or other related systems that would not be covered by Ford Warranty. Warranty coverage limitations should be discussed with your dealer prior to installation of this modification.
...Of course, we've pretty much found that a mild turbo setup will work on a 6.9, and a 7.3 can handle a decent bit of boost. Add headstuds, and you can put a *lot* of HP to the ground. It's only been recently where we've gotten pumps that will put out enough fuel to, say, break connecting rods doing 400+RWHP(aside from, perhaps, the P-pumped Hypermax engine from a long time ago).
Anyway, I'm pretty confident at this point about the 250RWHP on a stock 7.3; I'm still not sure what the limit of a 6.9 is, but it's over 5 PSI long term.
Edit: Here's an interesting topic from years ago about people running 12+ PSI on stock 6.9's... So perhaps they can handle more than I thought.
And the 1/2" bolts are quite a bit stronger than 7/16" ones
shawn deere
nebraska
Pave the way good sir!:popcorn
pelky350
Springfield, OR
I second the motion of 15 psi being safe on a 7.3 mines still here we shall see what happens! lol I'm only like 10k deep so far though lol but it's had a turbo for at least 30k now
Brian. Any turbo will spin upwards of 125,000 rpm. Thats more than 2000 rpm per second.
Staff online
