davlun
Ok, I will look for that clip.... perhaps i can just slide a piece of rubber in it and call it done? Will take a look when I get home.
Thanks!
Thanks!
Interesting on the kohler engines. I have a k662 (I think) - never used really as it is attached to a generator that was purchased at surplus in the 60's and stored away. Never had gasoline in it until I purchased it and dont believe it has ever had an electrical load as there were no receptacles ore wiring installed in the box for that purpose on the genie. I had heard some tractors had kohlers in them but never had confirmation until now.
Thanks for the help, thought you might find that interesting...
...so may be better off going with electric pump off a Powerstroke...
Ah yes, there is that. Well you can guess what we're running, Sagi-pumped evenJust remember, this is only if you have Hydroboost brakes. The Powerstroke electric pump is not designed for the demands of vacuum brakes. On the PSD,s it only runs the HVAC and the ESOF Hubs (If equipped). Stick with a mechanical pump if you are running vacuum brakes
