Eighty_six
I recently purchased a 86 f250. 6.9l with a turbo from a 94 7.3l installed. The turbo is mounted on the driver's side between the coolant recovery tank and engine, directly over the driver side exhause manifold. A turbo engineering intake horn mates the turbo to the intake. The down pipe appears to be a 2" custom job. Maybe 2.25" I haven't measured. It rubs on the front driveshaft.
Question 1: what aftermarket down pipe will fit without rubbing?
The CDR has been deleted which I've read is a good thing due to it causing higher egts in 7 and 8 cylinders. It steams like a tea kettle when warm but the amount of oil dripping seems minimal.
Question 2: how much is too much steam from RDT?
The drivers side of the engine is covered in oil residue. I unplugged the valley pan drain so no more pooling in valley pan but there's still a drip. (Less than a quart per week) it appears that the leak originates from around the rear (firewall) of the motor and my best guess is the head gasket.
Question 3: I'll post pics later this afternoon but is it likely for the head gasket to leak small amounts of oil such as I described above and if so could this also be the cause of the next question.....
I notice that under normal acceleration I get extremely little blue smoke (or none) but if I accelerate using about 1/2-3/4 throttle a puff of blue is evident at first then clears up. Intake is totally free of oil, as in no oil evident in intake. No oil in compressor side of turbo. No oil dripping from exhaust. Have not pulled apart exhaust closer to engine to see if there is oil upstream anywhere. It is also important to note that the passenger side of the motor is completely dry with zero apparent leaking anywhere.
Question 4: how much blue is too much and should I worry? If I need to change my head gasket is there a link to a write up?
Vac boost master is leaking between reservoir and... Ummm... Big round thing the reservoir is attached to. (What a noooob!)
Question 5: is there an o-ring or gasket between them that I can replace or is this a sign of failure and need to be totally replaced??
The steering has a mean soft spot in it. I've gotten used to it so driveability is fine but I'd like to tighten it up if I can. She has new tie rod ends, left and right. New u-joint in steering shaft.
Question 6: what steering components can be adjusted and how-to.
I'm sure there's more questions but those are the pressing ones or the ones I am most concerned about at the moment. Thanks in advance and if pics are needed please let me know what you need pics of so I can upload specifically.
Chris
Chris
